MGF Hardtop Rattles n Squeaks
Summer coming in fast down here in the Southern Hemisphere so am thinking of fitting the hardtop. Too hot over Summer here to run with the top down plus the hardtop really adds to the efficiency of the air-conditioning.
Last time I had it on I noticed that it squeaked and rattled quite a lot. And after removing the hardtop I noticed that the hardtop had scuffed the paintwork on the side of the car immediately below where to hood folds into the body.
Has anyone had issues like this before? Is it a case of having the adjustments two tight not allowing the hardtop to flex naturally?
Murray Arundell
Brisbane Australia
Murray Arundell
Brisbane Australia
by Deuss
- adamelphick
This might help..
https://www.mgfcar.de/hardtop/index1.htm
Older versions had bad foam rear seals and less/no adjustment on the hinges... Could be the problem?
Sent from my CLT-L29 using Tapatalk
by adamelphick
Time to create page: 0.849 seconds
