Twisted Knobs ?
Hi all my knobs are twisted don't know which setting they are on so who recommends which, want solid aluminium ?
by jelly
- sworkscooper
I changed my plastic knobs to MGMANIALTD.CO.UK aluminium ones but they are a bit on the chunky side . It depends on what style you are after . The Mania ones could do with being put on a lathe and shortened a tad .
John
John
by sworkscooper
Thanks John they do look chunky there was somebody advertising some on FB I said if they made them I would have a set but never heard anything so thought I would ask on here ?
by jelly
- adamelphick
I went for MY05 ones, I sunk them in to the holes though by enlarging the holes, and using a R200 backing I think it was. Did it ages ago now. Had to use the R200 becking as a template to cut the TF one to the right diameter to fit the rear of the knobs in to. Then they fit flush with a little lip hiding the actual hole they go in. Kinda neat look.
Sent from my CLT-L29 using Tapatalk
Last Edit:4 years 11 months ago
by adamelphick
Last edit: 4 years 11 months ago by adamelphick.
Time to create page: 1.437 seconds
