Inactive f
have not been on for a while nor driven my F. This is due to no mot and a broken handbrake cable and srs light. The cable is proving to be a real pain with limited access and seized rounded bolts. Yesterday after a lot of patience and copious heat I manage to free the last bolt. However still cant remove it due to hole in subframe not lining up. I am loath to dry and drop it though as I have a feeling that could prove even more painful. I am going to attempt to increase the hole with a grinder or possibly a step drill. Unless anyone has any other ideas? Does anyone know how the plate comes off its not loose so could it be stuck? Have removed seven bolts so far. Is this right.
Regards
Neil
Thank You
Thank You
Thank You
