Abs bleed system
Abs bleed system was created by Ant-75
Posted 4 years 9 months ago #192554
Can anyone help and advise me on the best option, I have a rover 75 2.0cdti 2003 preface lift and I’ve just carried out brake pipe and flexi replacement as well pads and disc , since then I’m unable to get a solid brake pedal it seems to slowly drop, I think there might be air in the abs unit ?, will the diagnostic/software that p scan have definitely do the job I need ( which is completely run and bleed the abs unit ) .
Please advise
Thanks Anthony
by Ant-75
Replied by talkingcars on topic Abs bleed system
Posted 4 years 9 months ago #192564
Hi and welcome to the forum.
Have you plugged your pscan in and read the ABS ecu?
James
Replied by Ant-75 on topic Abs bleed system
Posted 4 years 9 months ago #192569
Hi James
No I haven’t I’m looking at purchasing the p scan and I’m hoping that it will fix my problem I’m hoping it will pressure activate the abs pump to be 100% no air in the pump ?
by Ant-75
Posted 4 years 9 months ago #192571
It's a funny old world, someone else posted a similar question earlier which might answer your question
https://www.the-t-bar.com/forum/pscan-uk-diagnostic-tool-forum/96978-abs-power-bleed-on-a-rover75-cdti-automatic
Time to create page: 1.277 seconds
