Damaged thread in engine block?
Damaged thread in engine block? was created by rosey
Posted 4 years 8 months ago #192711
I've changed the Cam belt, water pump and tensioner on my TF (subject of another thread). When replacing the 4 x 13mm bolts holding the part of the engine mounting to the block, one of the bolts is very tight in the thread. All the bolts came out ok and I swapped one of the bolts so I know it's the thread. What do people suggest I do, carry on and risk stripping the thread, I'm really not sure.
Thanks
Jon
by rosey
Replied by adamelphick on topic Re:Damaged thread in engine block?
Posted 4 years 8 months ago #192712
What about running a correct sized tap into the hole to clean the threads?
Sent from my VOG-L29 using Tapatalk
Replied by Cobber on topic Damaged thread in engine block?
Posted 4 years 8 months ago #192713
Yeah retap the thread if the result is unsatisfactory, then you'll need to use a tread insert such as Helicoil or Recoil.
Last Edit:4 years 8 months ago by Cobber
Last edit: 4 years 8 months ago by Cobber.
Replied by rosey on topic Damaged thread in engine block?
Posted 4 years 8 months ago #192714
Thanks both for your advice. I've ordered an M10 tap
by rosey
Replied by sworkscooper on topic Damaged thread in engine block?
Posted 4 years 8 months ago #192715
Best of luck with the tap as I agree with the advice given . However I am from the motor industry and have found that unless the bolt was originally cross threaded you may find that you will need a Helli coil to sort it out . This is due invariably to the bolt's coated plating failing allowing oxidization ( corrosion ) to occur between the threads .
Without the protection of the plating , mild steel and aluminium react against each other and when the bolt is removed it takes part of the aluminium thread with it . Keep us in formed and best of luck .
John
Replied by gloscs on topic Damaged thread in engine block?
Posted 4 years 8 months ago #192716
Jon
Get hold of a tap the same thread and run it down to clean up the thread.
Mike
by gloscs
Replied by mgtfbluestreak on topic Damaged thread in engine block?
Posted 4 years 8 months ago #192737
Oil the tap:: :dry:
Last Edit:4 years 8 months ago by mgtfbluestreak
Last edit: 4 years 8 months ago by mgtfbluestreak.
Posted 4 years 8 months ago #192752
The tap worked a treat. I ran it down the thread with a bit of grease and the bolt then screwed up ok. Had to admit I chickened out and didn't tighten it to full torque but tight nonetheless.
Thanks for all your advice.
by rosey
Time to create page: 0.536 seconds
