E10 petrol
- sworkscooper
John
[size=10pt]Mark[/size]
95 MGF
The consequence of putting E10 fuel in an incompatible vehicle depends on the vehicle/engine variant and how much fuel has been put in.
It may cause some pre-detonation (‘pinking’), and perhaps a little rough running and poor cold starting, but it shouldn't be a disaster for the driver.
Simply top up with the correct fuel suitable for the vehicle as soon as possible when around a third to half the tank is used.
There has also been discussion in Historic vehicle circles about Ethanol for quite a while. The Federation of British Historic Vehicle Clubs has an interesting page about this https://www.fbhvc.co.uk/fuels , the main issue is that the fuel line components in many older Historic vehicles aren't compatible with Ethanol, but replacing older flexible fuel pipes with modern materials generally addresses this. The main issue for Historic vehicles will be fuel degradation of stored fuel, and increased risk of vaporisation and fuel locking where fuel lines get hot. i've seen posts elsewhere of this being addressed by installing heat shields or re-routing pipework and using the car more often!
(BP and Sainsburys offer 97 ron, Shell is 98 and Tesco is 99)
95 MGF
talkingcars wrote: The K series should run on E10 but for the few extra pence per litre I use 97-99 ron "super" when E5 isn't available....………….
mowog73 wrote: Where I live, even Super has ethanol. The refineries have reduced the amount of octane in the fuel from the refinery and make up for the octane reduction by adding ethanol to all grades of fuel because ethanol is a cheap octane booster.
Sorry maybe my post wasn't clear.
In the UK and in Europe regular fuel is 95ron and either E5 or E10.
Where 95ron isn't E5 I use the higher grade 97/98/99ron which is only ever E5.
it is worth noting that E5 is anything over 5.5% and under 10% ethonal
however from page 5
10. Introducing E10 will add to fuel costs paid by motorists. Moving from E5 to E10 is estimated to reduce pump price petrol costs by 0.2 pence per litre. However, as the energy content of the fuel will also decrease, motorists will have to buy more litres of fuel. Overall fuel costs for petrol cars are therefore estimated to increase by 1.6% as a result of moving from E5 to E10. (More details on these calculations can be found in annex C; but note that the estimated GHG saving of 1.8% already takes into account the impact of the lower energy content).
