TF alarm question
Hi,
I am new to this forum and I have a question regarding the alarm in my TF.
I bought the car last august and I dont fully understand how the alarm works.
Can I disable the alarm completely when I store the car over winter or when I am on the ferry to main Sweden. I am not allowed to have the alarm on when the car is on the ferry.
The alarm is also on efter a while when the car is parked but not locked, is this correct?
Regards
Bertil in SWEDEN
Regards
Bertil in SWEDEN
by Bertilk
The alarm system has several sections.
When you unlock the car with the fob you unlock the doors, switch off the alarm and switch of the starter immobilisation.
The car will remain unlocked and unarmed in some versions while other versions may relock the car and reset the alarm if a door isn't opened. The immobiliser normally switches off when the alarm is switched off but some models have a transponder in the fob that needs to be close to the ignition barrel to switch off the immobiliser.
Also the immobiliser will switch back on after the engine has been run.
The flashing light by the speedo shows that the immobiliser is in operation and the engine can not be started.
There are two main triggers for the alarm, voltage sensing primarily triggered by opening a door or the bonnet and in some cases a microwave sensor fitted behind the t bar in some models.
To avoid the alarm sounding but to otherwise secure the car lock it with the key in the key hole in the door, this will lock the doors and activate the immobiliser but will not set the voltage trigger or the microwave sensor. This should work on a ferry and I believe should apply to any car with remote locking.
by talkingcars
Thanks a lot!
I will try this when I take the car out of storage and I hope this can happen soon evenif it isstill cold and we see some snow showers now and then.
Regards
Bertil
Regards
Bertil
by Bertilk
- sworkscooper
Hi . Talkingcars is correct and that is how I leave my TF on a ferry and have had no problems over the last dozen or so trips to France .
John
John
by sworkscooper
Thank you both for your help!
Stay safe in corona ties!
Regards
Bertil
Regards
Bertil
by Bertilk
Time to create page: 0.494 seconds
