Engine harness 2001 vvc (manual without air con)
Engine harness 2001 vvc (manual without air con) was created by Sparksy
Posted 4 years 6 months ago #193075
Good afternoon folks,
I'm in need of an engine harness for my 2001 vvc part no. YSB113930. I've been unable to locate a used like for like harness, there appears to be numerous different MGF/TF harness available on eBay. Do I require the exact same harness or can I use an alternative MGF/TF harness?
by Sparksy
Replied by SundanceUK on topic Engine harness 2001 vvc (manual without air con)
Posted 4 years 6 months ago #193077
Contact Darren at MGFnTFBITZ .
He should be able to sort you out, and he is still trading by post at the moment.
Sundance
Replied by talkingcars on topic Engine harness 2001 vvc (manual without air con)
Posted 4 years 6 months ago #193081
The difference between the A/C loom and the non A/C loom is the inclusion of the 2 wires that go to the A/C pump and the length of the wires to the alternator as it is relocated, they can be extended if need be.
Posted 4 years 6 months ago #193082
What is wrong with your current loom?
Replied by Sparksy on topic Engine harness 2001 vvc (manual without air con)
Posted 4 years 1 month ago #194281
Sorry for the late reply. It became wrapped around one of the driveshafts and was severed. It looked worse than it actually was, in the end I repaired the broken wires and thus far it's been fine. That said, I'm still on the look out for a spare harness.
by Sparksy
Time to create page: 0.547 seconds
