Surging Steptronic
My '99 F Steptronic 'surges' when I am trying to move slowly such as when I am parking. This happens in both drive and reverse. It also engages drive and reverse with a definite 'clunk'. Otherwise it works fine. The tick over is correct as is the fluid level. The fluid and filter have recently been renewed which, initially, significantly improved the performance of the box. Any Ideas?
Frank
Frank
by WoodySye
Sorry, I don't know anything about the steppy.
by talkingcars
The following user(s) said Thank You: WoodySye
Has the correct fluid been put in the box ? It sounds like the oil shear point breaking down hence the clunk
Sent from my SM-G950F using Tapatalk
by Steve
Yes, definitely the one recommended. What exactly is the oil shear point?
Frank
Frank
by WoodySye
The shear point is the physical strength of the oil when in no longer lubricates, only in this case its hydraulic pressure.
by Steve
Thanks for that. We live and learn but I'm not sure that it takes me forward.
Regards
Frank
Regards
Frank
by WoodySye
All I can add is if it was ok to start and it's the correct Austin Rover spec oil, and the drive has deteriorated have you checked the oil level since initially filling ? Iwould be nice to know what the issue was if you get it sorted.
by Steve
Hi Steve
I checked the level only yesterday and it is up to the full mark. The 'surging' has now become a 'juddering' accompanied by a screeching noise so if you get any good ideas (or even half good), please let me know!
Frank
Frank
by WoodySye
Sounds like a torque converter problem..
I would be looking at the oil again or possibly gearbox oil pump..
Which oil was used/recommended by whom?
best of luck...
best of luck...
by MGmike
Time to create page: 0.533 seconds
