Immobiliser Bypass
My MGTF is in the garage at the moment, being repaired. However, every time they try to turn the car over, it turns over twice, and the immobiliser light kicks in on the dashboard and shuts it down. Once the keypad button is pressed it can then be restarted, but repeats the same process. I have the original type keys with the black fob.I am not sure what the options are for me. Can this be bypassed/disabled, if so does anyone know what the steps required are, so I can then inform my mechanic/technician, or if anyone knows anyone in the Milton Keynes area that can do this. Are there any other options available?
Pektron are round.
2002 is close to cross over.
Are yours round Pektron or rectangular Lucas?
I find I page to pay for a EKA code but whats is Registration Number? Can you help me?
- julianfoulger
You should emaîl them at https://www.radiocodes.co.uk/contact-and-about-us if unsure. The vin number should be enough. You should also buy a 2 fobs (ie 'controls'), the second fob being a spare in case you lose the first. There are 2 different FOBS, depending on the age of your car.. The fobs will need to be programmed to the car..
If that site can't help you, the pscan diagnostic tool can find the EKA tool for you and is also helpful in trouble shooting problems. https://pscan.uk/
Mark
Ontario, Canada
[size=10pt]Mark[/size]
95 MGF
In your situation I would consider buying a www.pscan.uk to access your alarm ECU and a couple of "fobs" to program in.
The pscan will also let you access the EKA code.
Alternately have a look at www.technozen-electronics.co.uk
