About to give up on my MGF - I think I have tried everything.
Replied by Cobber on topic Re:About to give up on my MGF - I think I have tried everything.
Posted 4 years 5 months ago #193521MPI, VVC or Trophy?
MEMs 1.9, 2J or 3?
Oh and I was editing my above post on the run, so you might want to reread it as there have been additions.
Replied by iambob on topic About to give up on my MGF - I think I have tried everything.
Posted 4 years 5 months ago #193522Bertl wrote: I had the same issue years ago - for me it was a clogged toggle valve in the inlet manifold. Try to clean it.
Yep it was clogged - cleaned it when I removed manifold. But still no joy.
Replied by Raccoon on topic About to give up on my MGF - I think I have tried everything.
did you renew the gasket when refitting the manifold?
Replied by iambob on topic Re:About to give up on my MGF - I think I have tried everything.
Posted 4 years 5 months ago #193524Cobber wrote: What year is it? 2001 - UK import
MPI, VVC or Trophy? MPI
MEMs 1.9, 2J or 3? MEM3
Posted 4 years 5 months ago #193525Bertl wrote:
did you renew the gasket when refitting the manifold? Yep new gasket too - I have been trying so many things
Posted 4 years 5 months ago #193526Are al the coolant hoses going where they should? Sometimes the minor hoses can be connected to the wrong nipples, this can cause interruption to the proper flow. I have spend a long time checking the water flow and pipes - removing checking and flushing. Trying to understand why the flow seems to run the bypass in priority to the radiator at idle. Can only ponder there is some sort of restrictor under the jiggle valve?
Lean fuel/air mixture can cause hot running, check for vacuum leaks, check sensors particularly temp sensors are correct, the wrong plug can be on the wrong sensor, so check all the plugs are on the right sensors. Have checked and replaced ECU temp sensor just in case it was giving wrong reading
Don't assume that anything is correct until its been properly checked. I assume nothing on a MG
Posted 4 years 5 months ago #193527Please Log in or Create an account to join the conversation.
Replied by Fiddler on topic About to give up on my MGF - I think I have tried everything.
Posted 4 years 5 months ago #193528So true .the body is good where it's solar red ..Any black powder coated items almost rusted away . Security panel below bonnet catch just almost not there .Think I'll leave it off. .Subframe just ok ..spare wheel panel and all red things like new . Great playthings
Replied by Steve on topic Re:About to give up on my MGF - I think I have tried everything.
Posted 4 years 5 months ago #193539That's what I had, bleed rad go for run, all fine while moving, overheat while standing all fans running, get home coolant raised in tank air in rad, all caused by exhaust gasses that sniff test failed to show but bore scope proved with wet cylinder when cool.iambob wrote: Just bled some more air out of the radiator after the last overheat. It was bled just before my drive so I think something is pushing it back in. Might have to see if I can get a sniff test.
Sent from my SM-G950F using Tapatalk
