Drilled a hole in the fuel tank
Epoxy putty is NOT suitable for HDPE, especialy a fuel tank.
It may be stronger than HDPE, but it has to bond to it to be any good.
Only specialist adhesives and preperation will bond to HDPE. They sort of disolve the surface to produce a chemical welding.
by G0RSQ
- mgtfbluestreak
Replied by mgtfbluestreak on topic Drilled a hole in the fuel tank
Posted 4 years 5 months ago #193597Please Log in or Create an account to join the conversation.
Update:
I moulded a plug from HDPE using the correct diameter for the hole
I then welded it onto the tank using a soldering iron
It’s not pretty, but I’m confident of the seal
Thanks for all your help folks
Last Edit:4 years 5 months ago
by cbbtoan
Last edit: 4 years 5 months ago by cbbtoan.
Just to be clear, Plastic Padding is NOT epoxy - it is polyester and definitely will not adhere to polypropylene!
by davidej
cbbtoan wrote: Update:
A week in, how's it holding?
by talkingcars
A year and 10 months later.... it's holding just fine thanks
by cbbtoan
