MGTF battery problems?
- sworkscooper
John
Not sure tbh, will checktalkingcars wrote: Does the engine speed rise slightly when you turn on all the heavy draw electrics?
I've found the engine earth strap connection to the firewall has some corrosion so will rectify this before alternator voltage checks.
Thanks
Voltage at back of alternator from cold 13.95v gradually falling as engine warmed up.
Switched on wipers, blower and headlights and battery voltage idling 13.2v and at back of alternator 13.8v.
Battery voltage @2000 rpm 13.56v (no change from idle- engine was warm by this time)
Alternator voltage at this time 13.88v. Alternator voltage @2000rpm with lights etc on, 13.77v.
Is it right for the voltage to drop off gradually as the engine warms up, indicating that the battery is charging? Do the voltages look right to people?
Grateful for any help
Thanks
Thanks
Thanks
