F completely dead - but only almost..?
Replied by Keymaster on topic F completely dead - but only almost..?
Posted 4 years 4 months ago #193828
You have confirmed that there may have been a faulty battery earth, and you now have current to the alternator ,but I am just checking that the fuse rating of 60 amps is enough, my alternator fuse is 80 amp. I know this because it blew after the fuse holder had almost burnt out due to a short in the cable. This disabled the car pretty quickly on the motorway and no way was it going to start.
The alternator fuse holder is located on the bulkhead just centre left looking from the back of the car below the grill. check the cables to it for damage.
Have you tried connecting and disconnecting the battery several times in succession? I'm sure I have read this somewhere that this can cajole the SCU into remembering the frequency between the fob and the SCU; although don't ask me how.
by Keymaster
The following user(s) said Thank You: StefanA
Replied by G0RSQ on topic F completely dead - but only almost..?
Posted 4 years 4 months ago #193832
You may need to syncronise the fob again. Normally done by pressing unlock (or is it lock ) several times in quick succession.
Happens occasionaly when replacing battery.
Make sure you get a second fob programmed! It will fail when you least want it to!
by G0RSQ
Replied by StefanA on topic F completely dead - but only almost..?
Posted 4 years 4 months ago #193834
Well, the alternator fuse that sat there were 60A so I replaced it with a similar, but the more I google it the more about 80A I find. Strange indeed.
I'm going to try to resync the fob tomorrow (with the horn blaring) and if it doesn't work I'll renew the battery in the fob.
Thanks!
Thanks!
by StefanA
Posted 4 years 4 months ago #193836
It's alive!
Once I realised that I had to unlock the door with key first, before pressing the lock button several times - and pretty rapidly too - it finally reacted to the fob and then started like a dream.
Still have to take a look at the starter, but that's for the winter.
Thanks a lot, boys!
Thanks a lot, boys!
by StefanA
Replied by Raccoon on topic F completely dead - but only almost..?
Posted 4 years 4 months ago #193837
That's great news!
:woohoo:
:woohoo:
by Raccoon
Time to create page: 0.485 seconds
