Puddle lights in door cards
Puddle lights in door cards was created by Fil6909
Posted 4 years 3 months ago #193906
Here's an easy ish upgrade .. few pics to assist , fit puddle lights, I included a ( 'doors open' ) red light too while I had the door card off .
I used number plate illumination led lights for puddle lights , off flea bay for 5 or 6 quid, & a couple of round red lights from same source.
Carefully cut an aperture into a desired position in the door card - rear side of the grab handle offers plenty of space ( repeated careful cuts with a Stanley worked for me), similarly with the red lights ..as wide as you can really ..make sure there is enough clearance behind the door card & the fitting is not fouled by the metalwork of the door itself, or you will have an unwanted hole in your door card.
Piggy back the connectors ( see the pics)from the footwell lights & run the wires around the footwell ,tho ugh the door trunking duct with a wire 'fishing' device and then behind the card.
I found it easier to go from the door to the footwell with a wire & pull the cable back .
Wire up like pole wires ,insulate properly and refit the door card after a brief test .
When the doors open the lights all come on together.
Good luck
Easy peasy really ..slow and steady is the order of the day.
Last Edit:4 years 3 months ago by Fil6909
Last edit: 4 years 3 months ago by Raccoon. Reason: pics added
The following user(s) said Thank You: Raccoon
Replied by talkingcars on topic Puddle lights in door cards
Posted 4 years 3 months ago #193908
Nice one. I added some round logo puddle lights in the bottom of the door which look cool.
Replied by Fil6909 on topic Puddle lights in door cards
Posted 4 years 3 months ago #193944
Nearer the floor obviously in the base of the door .. but I thought easier cutting in the door card & led lights are bright enough for the slightly extra height ..cheers.
by Fil6909
Posted 4 years 3 months ago #193968
Looked hard for the logo ones... without success obviously .. they will look cool.
Seemed to have every motor ,except MG, heh no.
by Fil6909
  • psymon
  • 2001 MGF 1.8 in MNX
Posted 4 years 3 months ago #193973
Thanks for the link .. have to re jig the light show now .
by Fil6909
Posted 4 years 3 months ago #193974
Ps. How big is the logo projection ( diameter?) cheers
by Fil6909
Replied by Keymaster on topic Puddle lights in door cards
Posted 4 years 3 months ago #193983
I like them,.....I wonder how far they would project the logo. Just thinking of putting them in the bonnet to project MG into space.
(I am joking i think)
Posted 4 years 3 months ago #193990
Fil6909 wrote: Ps. How big is the logo projection ( diameter?) cheers
IIRC mine are about 12" across.
Posted 4 years 3 months ago #193991
The logo on one of mine has failed :(
Time to create page: 1.503 seconds
