Help with horrible noise pleas
Trundling along at just over 2,000rpm on a straight road with hardly any throttle when there is a horrendous clanging from behind me which sounds like something being dragged along the road.
Pulled over straight away, the noise is coming from the engine bay, possibly the RH side, rev related and sounds like a metal to metal clanging.
There was nothing obvious so I decided to limp home. Made a U-turn (to the left here in France) and the noise reduced during the turn and had disappeared by the time I was straight in the other direction.
20 or so miles since, running perfectly, no unusual noises, revs freely and ticks over as normal.
Approx 32,000 miles, about 14,000 since cam belt change (but about 6 years, intend to change soon).
Any comments or clues would be most Welcome.
What's that black canvas thing behind the seats for?
- mgtfbluestreak
Replied by mgtfbluestreak on topic Help with horrible noise pleas
Posted 4 years 3 months ago #193966Please Log in or Create an account to join the conversation.
FrenchTF wrote: But the noise was revs-related at a standstill?
Sorry, missed that bit.
The cambelt looks OK (passes the 'leaves slight mark if you press it with a screwdriver' test), the tension is OK, there is no leak around the water pump and there is no apparent damage to it or the alternator. No bearing play on either so far as you can tell.
But. The alternator belt is slightly damaged along the outer edge (yellow circle in photo) and there are some fibres trapped on the pulley (red circle). No apparent damage to the pulley.
Any opinions would be most welcome.
Also is there any harm in starting the engine with the upper cam cover removed - something might become more obvious?
- sworkscooper
John
Replied by David Aiketgate on topic Help with horrible noise pleas
Posted 4 years 3 months ago #194023Wot he said!Cobber wrote: Don't feck about, any doubt, hurl the old belt out!
Fibres degrading from the Alternator belt can get into the cambelt casing and cause major engine damage.
One of the most common causes of catastrophic engine failure!
- sworkscooper
:nonod:
Everything checks out, no unusual noises, pullies running true etc - just the damaged alternator belt.
This time it stopped in a more revealing place - it looks like something has stripped one edge off the belt and there is some damage to one of the internal ribs, the pullies look fine.
I'm working on the 'foreign object' theory, although what and how it could have flicked up is a mystery.
About to order new cambelt kit (due anyway) and alternator belt, should solve the problem.
