Rear Brake Calliper Carrier Slider Pins (MGF/TF/Rover 800)
Rear Brake Calliper Carrier Slider Pins (MGF/TF/Rover 800) was created by g4wam
Posted 4 years 3 months ago #194270
Hi all,
just wondered if any one out there can help with the following query..
the rear brake callipers slider pins on MGF/TF are the same as Rover 800 and the ancillary items are the same as well , but why is the profile of the slider pins different on the same calliper (upper/lower) see attachment .
As they are different in profile what is the correct positioning when fitting into the carrier
Mike
by g4wam
Replied by gloscs on topic Rear Brake Calliper Carrier Slider Pins (MGF/TF/Rover 800)
Posted 4 years 3 months ago #194275
Hi Mike,
Design changes happen all the time for various reasons, new parts supercede older ones, the date of manufacture will determine the latest version, check the date range on the box to establish the latest version. Bear in mind that changes may or may not affect cross platform products.
Having said all that, I would err on the side of caution where brakes are concerned.
Mike
by gloscs
The following user(s) said Thank You: Raccoon
Time to create page: 0.470 seconds
