MGTF steel Heater Pipes
Has anyone fitted the (gear cable tunnel) heater pipes? Wondering how difficult it is, so looking for hints tips and any problen you have experienced.
Regards
Robert
Mike
I would have thought that the center consul would have to be removed, but not sure?
Robert
Fisher wrote: ......I would have thought that the center consul would have to be removed, but not sure?
Robert
Even then I'm not sure they will come out easily, the best option is to slide the pipes out in to the engine bay when the subframe is out.
I have been toying with the idea of taking a feed off the hoses at the front where they run to the cooling rad, and also fitting a front mounted PRT.
Add to this the rear pipe/cable closure plate is a pig to remove (rusty bolts - surprise!).
So not an easy job "Well done" MG-Rover Designers.
Robert
- julianfoulger
Fisher wrote: Speaking to a couple of mobile mechanics. It appears that the removal of the pipes is a real pain in the rear. Have been told that the T Bar needs to be remobed and the arm-rest down to the cubby etc. The centre consul needs to be removed and one said also the seats ( but I think that was more for removal comfort). Trying to remove them from the rear, again, one mechanic indicated that the subframe needs to be dropped!
Robert
Fully concur. The closure plate is a pain but can be done, with replacing the pipes, without a subframe drop. Mind you, I took a week to do it (ie I took my time). I remember that there was one particular bolt that was right behind the subframe. Got it our using a small spanner but took a couple of hours.
