Can anyone Identify this coolant Pipe?
Can anyone Identify this coolant Pipe? was created by Fisher
Posted 4 years 1 week ago #194597
Hi All
The following picture shows a coolant pipe (No 14) by I cannot identify it on Rimmers or other MG spares sites. Tried a visual search on the web but no luck.
Does anyone know the part number?
Also, in the experience of the forum members which is the most vulnerable engine bay coolant rubber pipe for failure?
Regards
Robert
Last Edit:4 years 1 week ago by Fisher
Last edit: 4 years 1 week ago by Raccoon. Reason: pic added
Replied by julianfoulger on topic Can anyone Identify this coolant Pipe?
Posted 4 years 1 week ago #194599
If you are looking for the pipes that go to/from the heater - PEH100850 and PEH100850UR.
But the diagrams are not clear so I understand your question. The better diagrams have always been the Microfiche which the dealers used in the 90's. More accurate and complete.
Last Edit:4 years 1 week ago by julianfoulger
Last edit: 4 years 1 week ago by julianfoulger.
Replied by mowog73 on topic Can anyone Identify this coolant Pipe?
Posted 4 years 1 week ago #194600
Does this help? This is microfiche is for very early cars so the part numbers may have been superseded.
[size=10pt]Mark[/size]
95 MGF
Last Edit:4 years 1 week ago by mowog73
Last edit: 4 years 1 week ago by mowog73.
Replied by Fisher on topic Can anyone Identify this coolant Pipe?
Posted 4 years 1 week ago #194601
Hi Mowog73
I see in your pic that small 90 degree pipe (14) I am trying to find the part number does not exist. Your microfiche shows that the end of the steel heater pipe goes straight into your microfiche number 5 pipe. So I assume that my image if you ignore pipe 14, it may also go straight into pipe 15 in my image.
Confusing or what, considering my image cam from the workshop manual. So, I think I will rely on your image.
Thanks
Robert
by Fisher
Posted 4 years 1 week ago #194602
Hi Robert,
Yes, 14 is part of 15, which is coolant house PEH000090. It is confusing.
I'm working at converting parts microfiches for 1997 and 1999 into pdf, hoping that confusions like this will be made clearer by being able to look at these different microfiches and see what part was superseded by another.
Mark
95 MGF
by mowog73
Posted 4 years 1 week ago #194606
Matk
I see you pic for is an MGF. My car is a TF (2004). Would you anticipate the hoses to be different?
If not am happy to use your microfiche.
Regards and thanks for your time and input.
Robert
by Fisher
Posted 4 years 1 week ago #194608
Looking at Rimmer's website, they do say up to a certain VIN for that hose, so I think its for all cars, whereas there is a different section for hoses associated with the thermostat, which is different between the cars.
Mark
95 MGF
by mowog73
Posted 4 years 1 week ago #194611
Those hoses are part of the interior heater system, not the engine coolant system.
95 MGF
by mowog73
Replied by talkingcars on topic Can anyone Identify this coolant Pipe?
Posted 4 years 1 week ago #194614
Fisher wrote: I see you pic for is an MGF. My car is a TF (2004). Would you anticipate the hoses to be different?
Robert - the big change is that earlier cars had a thermostat in the block, later cars have a remote PRT.
James
Replied by BruceTF135 on topic Can anyone Identify this coolant Pipe?
Posted 4 years 1 week ago #194615
mowog73 wrote: Those hoses are part of the interior heater system, not the engine coolant system.
Ah, sorry.
The listing says "These hoses connect the engine bay hoses to the steel pipes that pass through the tunnel between the seats to the heater". I thought that was what the OP was looking for. TBF, the listing also says they are for cars without a PRT, so they'd probably be wrong for a 2004 car anyway.
Time to create page: 1.409 seconds
