Track Day next week
I'm an experienced historic racer of many years but this will be the first time that I've taken my newly acquired TF160 on track.
My car is in good order and has just had a major service including new cambelts and has also had 4 wheel alignment.
The engine has a Kmaps ecu upgrade, sports exhaust and a Pipercross air filter.
I will be running it with a hard top on and xpower Mk.1 roll hoops, torque tamer poly bushes, Satur brake servo bracket upgrade, Mintex M1144 front pads and new Toyo Proxes. If I can get it painted in time I may also have a Moto-build front splitter fitted.
Any set up tips such as tyre pressures for track days for either wet or dry running would be most welcome.
Hope you enjoy your track day...Mallory Park is a fun place to spend a day.
I've been advised by Mark of Kmaps that it is quite common to disable the power steering by removing the fuse in order to improve steering feel. Anyone tried this?
Removing the fuse will disable the EPAS, but you'll almost certainly have a dash warning light on. That's the only negative I think. If you're going to spend most of your time trackside, you can bypass the system to get rid of the dash light. Whilst on the circuit, just put a bit of tape over the light, so you're not distracted.
If you've not already done so, switch the clock and oil temperature gauges, so oil's nearer your eye line. It's a 5 minute job.
If you didn't get round to fitting the front splitter, leave the spare wheel in place under the bonnet. The extra front end weight helps cornering balance and therefore lap time, more than having a lighter car.
Let us know how your day goes.
Winko
Disabled was soooo much better!
We also got the front splitter fitted in good time.
Grey car on a very grey day!
There are many more posted on here:
https://www.flickr.com/photos/javelintrackdays/50690428343/in/album-72157717197664058/
The TF had an off at Gerrards and went into the barriers, when he recovered back to the pits a few mods with a crowbar and he was back out again.
The driver told be he bought the car off ebay as a non runner only because the keys were locked in the boot for £200!
What tyre pressures did you settle on?
Winko wrote: The Moto-build front splitter looks very good. Was it the Elise MkII one you fitted, and how much modification was necessary?
I went with 28F/36R and didn't play around with the pressures because the weather was so poor.
The splitter is specific to the TF and is a very tight fit. I believe it was moulded from an original MG Sport and Racing item.
See here: https://www.moto-build.com/
This picture shows the splitter a bit better:
