Lambda sensor part numbers (MG TF160)
- RickyGlasgow
- Apprentice MGer
Lambda sensor part numbers (MG TF160) was created by RickyGlasgow
Posted 3 years 11 months ago #194787
Hi there. I can't find much on this, even on the excellent PN finder at https://www.the-t-bar.com/forum/21-david-aiketgates-guides/185-part-numbers-how-to-find - likely 'user error', but I want to be confident I'm getting the correct part - anyone?
[Rationale for wanting to change: I'm putting in NGK iridium plugs, plus new coil packs and HT leads, and, well, am I going to get the benefit from that if the ECU is getting garbage information from the lambda sensor?]
by RickyGlasgow
Replied by talkingcars on topic Lambda sensor part numbers (MG TF160)
Posted 3 years 11 months ago #194800
Personally I would stick my www.pscan.uk on the car and see what readings I ma getting from the probe.
by talkingcars
- RickyGlasgow
- Apprentice MGer
Replied by RickyGlasgow on topic Lambda sensor part numbers (MG TF160)
Posted 3 years 11 months ago #194814
Indeed - I know someone who could likely help me out here. Either way, does anyone know the recommended part number?
Thanks!
Thanks!
by RickyGlasgow
- SundanceUK
Replied by SundanceUK on topic Lambda sensor part numbers (MG TF160)
Posted 3 years 11 months ago #194815
Call Darren Hardy at MGFnTFBITZ he will have the part numbers and probably the sensors if required and at competitive rates.
They are a great place for all our spares new or used.
Sundance
Sundance
by SundanceUK
- RickyGlasgow
- Apprentice MGer
Posted 3 years 11 months ago #194816
Thanks for the tip! I'll post back here if/when I get the info.
by RickyGlasgow
- RickyGlasgow
- Apprentice MGer
Posted 3 years 10 months ago #194983
Darren at MGFnTFBITZ very helpful. For the record, see attached the part he supplied (Bosch LS 6127)
Last Edit:3 years 10 months ago
by RickyGlasgow
Last edit: 3 years 10 months ago by RickyGlasgow.
The following user(s) said Thank You: Raccoon
Time to create page: 0.504 seconds
