Hand brake dash light
Hand brake dash light was created by mrtsbrother
Posted 3 years 10 months ago #195016
The dash warning light comes on at the slightest bump on the road, only going off when the handbrake is totally at the bottom. Could a kind soul direct me to the right bolt to loose /tighten? Cheers!
Sent from my Pixel 2 XL using Tapatalk
Replied by G0RSQ on topic Hand brake dash light
Posted 3 years 10 months ago #195018
Before adjusting any cables/switches, I would advise you to check the rear brakes and service the calipers.
Flashing handbrake light is often a symptom of the handbrake mechanism in one of the calipers sticking.
There is a lever in each caliper that needs to freely move back under its own spring tension, and they often start sticking. If it gets too bad, handbrake efficiency deteriorates and new calipers are required.
by G0RSQ
Replied by Roverlike on topic Hand brake dash light
Posted 3 years 10 months ago #195019
You should also check brake fliud level, since you may suffer from low brake fluid and your brakes might not work as they should. For your info handbrake light on the dash will illuminate if handbrake is up or if you brake fluid is low.
Replied by mrtsbrother on topic Re:Hand brake dash light
Posted 3 years 10 months ago #195020
Many thanks. Do you think that's likely given the light goes out when the handbrake is at its lowest position? I will investigate though.
Replied by BruceTF135 on topic Re:Hand brake dash light
Posted 3 years 10 months ago #195021
It is true that the light indicates low brake fluid as well as the handbrake on.  Since you say the light goes out when you push the handbrake lever down, it suggests that the problem is with the handbrake and unfortunately this seems to most usually be down to a sticking caliper.
But, it only takes a moment to check the brake fluid so I would eliminate that first.  Running out of brake fluid could be catastrophic while a sticky caliper will be a nagging problem that gradually deteriorates.  In the scheme of things, the problem you describe seems quite common in the MGF/TF and it's not too hard to fix.
Replied by julianfoulger on topic Re:Hand brake dash light
Posted 3 years 10 months ago #195027
Often it is the light switch which is underneath the hand brake. It just needs adjusting.
