Low(ish) voltage from alternator
Low(ish) voltage from alternator was created by GN09MGU
Posted 3 years 9 months ago #195150
I assume this is probably a regulator fault but thought I would post on here anyway in case there is a TF quirk. My battery ran low a few weeks ago due to near zero car use. Charged it. All well. And from this I know the alternator was putting out about 13.8, because I measured it at the time. Today, a few hours after retrieving the car from the MOT tester, I noticed the alternator light was on. Checked the voltage - 13.2. Engine off. Engine back on. Light out. But voltage still 13.2.
by GN09MGU
  • Away
Replied by Cobber on topic Low(ish) voltage from alternator
Posted 3 years 9 months ago #195154
Before you do anything, check that the connections to the battery, alternator starter motor and ground are clean and tight.
Shitty conections can impair optimal charging performance.
Replied by SundanceUK on topic Low(ish) voltage from alternator
Posted 3 years 9 months ago #195163
The battery will drag the voltage of the alternator down a little bit as it charges the battery up. I noticed this as I charged mine up after jump starting it when flat and then running the car and monitoring the voltage from my built in voltmeter. It gradually climbs as the battery charge increases. Mine took about 30 mins to creep up from 13volts to 13.9 volts while driving, It could be that your battery has seen better days. Also remember that running the heater fan will drop the battery charge a little, as will lights, rear windown heater if you have one etc. Switch all these off to get a true reading of your battery.
Sundance
Replied by GN09MGU on topic Low(ish) voltage from alternator
Posted 3 years 8 months ago #195204
The battery is less than 2 years old. The readings I obtain are quite erratic, and don't correlate with the alarm light being on or off.  I will need to monitor this for a while....
by GN09MGU
Posted 2 years 10 months ago #198173
A new alternator fixed this.
by GN09MGU
Replied by talkingcars on topic Low(ish) voltage from alternator
Posted 2 years 10 months ago #198202
Thanks for reporting back, it's always useful for others searching for resolutions to their problems.
Time to create page: 0.490 seconds
