Re: Exhaust manifold
engine oil was created by Sims
Posted 3 years 8 months ago #195268
Can any one advise me what type of engine oil to put into a LE500. Semi-synthetic or fully synthetic and whether 10w/40 or 5w/30 is best.
I have looked on Halfords oil tool with my car details and it recommends no oils are suitable for my car. The car handbook wasn't to helpful.
I am having to remove my oil filter to get a new ss exhaust manifold in. Well hopefully get it in with oil filter removed. It won't go in from the top
Thanks
Best wishes
Simon
by Sims
Replied by Steve on topic Re:engine oil
Posted 3 years 8 months ago #195269
Sims wrote: Can any one advise me what type of engine oil to put into a LE500. Semi-synthetic or fully synthetic and whether 10w/40 or 5w/30 is best.
Thanks
Best wishes
Simon
10w/40 Semi synthetic is the correct oil, synthetic is also acceptable but un necessary.
by Steve
The following user(s) said Thank You: Sims
Replied by Sims on topic Re:engine oil
Posted 3 years 8 months ago #195270
Many thanks Steve. I will get some 10w/40 and get on with manifold installation tomorrow. Simon
by Sims
Replied by David Aiketgate on topic Re:engine oil
Posted 3 years 8 months ago #195277
:welcome2:
I'm a bit confused by your post. Its pretty easy to fit the exhaust manifold from the top!
You do know about the engine access panel under the rear window?
https://www.the-t-bar.com/forum/22-cjjs-guides/2169-engine-inspection-panel-how-to-remove
Last Edit:3 years 8 months ago by David Aiketgate
Last edit: 3 years 8 months ago by David Aiketgate.
Replied by talkingcars on topic Re:engine oil
Posted 3 years 8 months ago #195283
As per Steve semi 10w/40 is perfect.
IIRC the LE500 has a cat in the down pipe so has that affected fitting the manifold?
James
Posted 3 years 8 months ago #195285
Hi David and James,
                                 I have managed to get the old manifold out the top. I had removed the alternator but left the  air con compressor in place as the air con system is charged. That was reasonably easy. I took away the flexy pipe going back to the cat as well.
However Installation of a Mike Satur 421 manifold has been a bit of a nightmare today. It won't go in the top without possibly removing the air con but not convinced it will even if I do remove the air con.
I have removed the engine torque tamer from the sump to the subframe (will polybush this) and I have removed the engine oil filter to give access. Even with a trolley jack pushing  the rear of the sump up, the manifold won't fit through the gap between the engine and the cross member as the exhaust heat shield bracket that is half way down the manifold stops the manifold being advanced upwards. The pipe work just squeezes through at its widest part
I gave up this evening after several hours of fun but my plan A tomorrow is to cut the fouling heat shield bracket off and hopefully I can get the manifold in from below.Plan B will be trying to find someone to degas my air con but that will probably happen post lockdown.
If you have any advice I would most grateful.
Best wishes
Simon
by Sims
Replied by Steve on topic Re:Re:engine oil
Posted 3 years 8 months ago #195286
Sims wrote: Hi David and James,
Best wishes
Simon
I've not done it but I read somewhere that to fit the MS manifold you have to jack the engine up slightly with the torque tamer removed to give a slight tilt to the engine.
by Steve
Replied by Sims on topic Re:Re:engine oil
Posted 3 years 8 months ago #195287
Hi Steve,
               Thank you. I tried that with torque tamer removed but heat shield bracket of the back of the manifold fouls access by a centimetre. Scared to continue jacking up the engine further and further.  I will chop the bracket off tomorrow and hopefully it will advance upwards.
best wishes
Simon
by Sims
Replied by gloscs on topic Re: Mike Satur manifold
Posted 3 years 8 months ago #195288
Why don't you contact Mike Satur, he's on facebook, or directly though his web site 🤔
From one of the reviews on Mikes site "The system went together beautifully and only needed the engine lifting to make space to get the manifold located"
Last Edit:3 years 8 months ago by gloscs
Last edit: 3 years 8 months ago by gloscs. Reason: Update
Replied by Sims on topic Re: Mike Satur manifold
Posted 3 years 8 months ago #195291
Cheers. Good advice. I phoned Mike and exhaust goes in from the bottom. I probably need to swing the engine a bit more to gain enough access.
by Sims
Replied by talkingcars on topic Re: Mike Satur manifold
Posted 3 years 8 months ago #195295
Have you raised the car up on axle stands?
That may help with you quest.
Replied by Sims on topic Re: Exhaust manifold
Posted 3 years 8 months ago #195297
Hi James,
                I have got her on hydraulic ramps at the rear and also axle stands for safety. Torque tamer is out . I am hoping the quest is nearly over.
Many thanks
Simon
Last Edit:3 years 8 months ago by Sims
Last edit: 3 years 8 months ago by Sims.
