Re:Using lacquer
Using lacquer was created by rosey
Posted 3 years 8 months ago #195340
Hi all
I've been doing a bit of de-rusting on my TF135 at the front edge of the offside sill, having removed the arch liner and cleaning out the crud behind it. I've primed the area and now need to apply top coat. My question is, when do you apply the clear coat, I've read that it should be done before the top coat is dry, also read the opposite. Also what is the best way of blending/polishing. I know it's difficult getting a good finish with rattle cans so would be grateful for any tips anyone has to get the best finish that I can.
cheers
Jon
by rosey
Replied by BruceTF135 on topic Using lacquer
Posted 3 years 8 months ago #195345
Good question! I have been deliberating over the same job on mine but keep putting it off due to the same uncertainties.
Replied by Steve on topic Re:Using lacquer
Posted 3 years 8 months ago #195346
All I can add is that at the factory (ex employee) the base coat was flashed off (semi dry) before clear coat, I allow about 20 minutes with rattle cans and dust coat little and often and I have achieved good finishes.
by Steve
Replied by rosey on topic Re:Using lacquer
Posted 3 years 8 months ago #195353
Thanks Steve, will try this. Is there a way of trying to blend in a repair once the lacquer is dry?
cheers
Jon
by rosey
Replied by Steve on topic Re:Re:Using lacquer
Posted 3 years 8 months ago #195354
If you are very careful you could use a very fine wet and dry paper to feather in the two surfaces but you really need a da polisher to cut it back again, personally I would just cut it back with something like g3, I have used brasso in the past to cut laquer by hand to good effect but it does take some effort but is less aggressive. Good luck
by Steve
The following user(s) said Thank You: rosey
Time to create page: 0.497 seconds
