Is this what I think it is?
Is this what I think it is? was created by Richardlce
Posted 3 years 8 months ago #195355
Am I correct in thinking that the head gasket has or is failing.
MG TF 2005 model year 49,000 miles
This was dipped out of the expansion tank.
I only did the cam belt at Christmas and have'nt used a tankful of fuel since.
Any helpful comments?
  • Away
Replied by Cobber on topic Is this what I think it is?
Posted 3 years 8 months ago #195356
Well oil in the coolant usually looks like tockley snot. was that shit floating on the surface? Or did you dreadge it up from the bottom of the tank? It looks a bit like some sort of head gasket sealing goop.
Do a compression test and a cooling system pressure test, to rule out head gasket failure.
Last Edit:3 years 8 months ago by Cobber
Last edit: 3 years 8 months ago by Cobber.
Replied by Richardlce on topic Is this what I think it is?
Posted 3 years 8 months ago #195357
Hi Cobber,
It was floating in the expansion tank, I put the cardboard in and it stuck when I pulled it out. There is no evidence that the HG has ever been changed.
There are no other symptoms that I can see.
Has anyone tried the cheap "Combustion gas in the coolant" tests?
Replied by talkingcars on topic Is this what I think it is?
Posted 3 years 8 months ago #195363
Is there more of this in the header tank?
What is the underside of the main oil cap like?
What is the oil on the dip stick like?
Posted 3 years 8 months ago #195364
Hi talkingcars,
No, there are a few spots, but no more big clots like this one.
Underside if the oil filler cap is clean, with a few beads of what looks like condensation, no milkyness.
Oil on the dipstick is clean, it was only changed a few hundred miles ago, along with the filter.
Posted 3 years 8 months ago #195366
In that case I would carry on as normal monitoring it as part of every pre use inspection.
Posted 3 years 8 months ago #195369
Thank you, I will do that and see how it goes.
I am not expecting to do any long trips at the present time!!!!.
Thanks for all your help.
Time to create page: 0.489 seconds
