For those who have installed an integrated multi-media head unit
Over the weekend, I ditched my MGF factory fitted head unit (which I shall keep in storage in case...) and fitted an all-singing, all-dancing Pioneer multi-media head unit. All working except that some functions are greyed out until I have connected the 'handbrake' lead. I do not want to do a cheat so the question I have is for those who connected this lead up properly, where exactly did you pick up the connection point? It is supposed to be connected up to the power side of the handbrake. Before I start to unwind miles of wiring loom to find the correct wire, it would be nice to ascertain how others did it. Many thanks for your help.
The electrical circuit diagrams available from the Community tab on the site should help.  There is a 'live' feed to the handbrake switch and brake fluid level switch (they share a warning light) which comes from the dashboard brake warning light.  In the TF, it's black/white.
Yes, I have all the diagrams at home and you are right - it is the Black and white tracer wire (MGF as well). In the absence of any advice, I shall break into the wire at the passenger fuse box.
It is easy to get to the handbrake switch by popping out the ashtray and maybe the lower box in the console between the seats.
Run a feed down the dash to the switch.
Time to create page: 0.521 seconds
