Oil Change
Oil Change was created by neilpinleeds
Posted 3 years 7 months ago #195530
Does the oil have to be replenished via the top of the engine?
If so, why can't it be filled via the remote filler, other than it will take some time?
Thanks.
Replied by gloscs on topic Oil Change
Posted 3 years 7 months ago #195531
The remote filer is really for topping up but I always use it for oil changes unless I have the engine cover off. As you say it's a slower process but I'm not normally in any hurry.
Mike
by gloscs
Replied by talkingcars on topic Oil Change
Posted 3 years 7 months ago #195532
Hi and welcome to the forum
The bottom of the top up tube goes to the hole in the block that is used for the dipstick on front engines cars.
The tube drains straight into the sump so if filling through here you miss out coating the engine internals in fresh oil that has filtered through.
James
Time to create page: 0.509 seconds
