mgtf headlight beam pattern
I cant find anything in the guides or forum on adjusting the headlights to the correct height and angles I know how to adjust them just not what is legal or correct
Can the group help please
by Tenko123
- julianfoulger
Do you have the proper kit to measure the beam pattern?
I could not find the numbers in the workshop manual but on my MGF I have labels that say 2 degrees dip but nothing on how much to the side the beam should go.
I suspect the actual setting is based on the actual suspension height of the car. Like you, I could find nothing on the web that quotes exact measurements.
EDIT: I found this link - it leads to a pdf. It is more complicated than I thought!
https://mattersoftesting.blog.gov.uk/wp-content/uploads/sites/19/2016/03/Headlamp-aim-changes-for-24-March-2016-Classes-3-4-5-and-7.pdf
Last Edit:3 years 6 months ago
by julianfoulger
Last edit: 3 years 6 months ago by julianfoulger.
The following user(s) said Thank You: Tenko123
No just a wall on a level drive way
by Tenko123
- sworkscooper
Hi . I think if it was me I would wait until MOT test time and slip the tester enough for a couple of pints and ask him to adjust them on the approved beam setter or go along to your local garage and ask for a favour . Its all very well lining it up on a garage wall or similar but unless you have the correct equipment you will be a country mile out of where they should be .
John
John
by sworkscooper
Time to create page: 0.461 seconds
