Alternator failed?
I've been using the TF a lot recently without any problems until today. Last week on the way home the battery charging light came on. Pulled over to check the alternator belt was OK, left the engine running, and when I got back into the car the light had gone out.
Used the car over the weekend for a short journey, no issues.
Went to use the car today, all appeared OK, but got a mile down the road and the car started shutting down, warning lights coming on and the power steering stopped working, but not the battery charging light. Coaxed the car home. So I'm assuming the alternator has packed up but if so why was the battery warning light not come on again, after the initial time last week?
by Gavin207
Does the alternator light come on when you switch the ignition on before you start the car?
by talkingcars
No it doesn't, so I took it out last night and it has continuity through it so appears to be OK. I've now charged the battery and with the engine running get 11.55v across the battery, no change when I rev it. I've got the alternator out to check for any obvious faults of which there are none, so last stage is to put it back in , check all earths and give it another go, if still no charging then I assume dead alternator?
by Gavin207
- BruceTF135
One quick and easy thing to check is the alternator fuse. . Is the diode pack replaceable on the TF alternator? I don't know.
Also, a fully charged battery should supply about 12.5V, not that this sounds like your problem.
by BruceTF135
- BruceTF135
It's called an alternator regulator. Available online and from ebay, e.g.
Oh. Just noticed that the eBay widget doesn't work anymore. Try here:
Last Edit:3 years 6 months ago
by BruceTF135
Last edit: 3 years 6 months ago by BruceTF135.
The following user(s) said Thank You: Gavin207
