Door hinge wear - bushes, pins or both?
Door hinge wear - bushes, pins or both? was created by Gavin207
Posted 3 years 5 months ago #196025
My door hinges are worn, but before I invest in the replacement of the pins, can anyone tell me if both parts wear or only the bushes? I ask as if the pins don't wear i may make my own replacement bushes as I have the required resources to do this, but if the pins also wear them I'll probably just invest in the  Mike Satur kits.
Replied by talkingcars on topic Door hinge wear - bushes, pins or both?
Posted 3 years 5 months ago #196026
I think the pins do wear. The doors on our 130k P reg had dropped so my lad took the pins from our T reg 48k donor car which certainly improved things.
Replied by Prof Riley on topic Door hinge wear - bushes, pins or both?
Posted 3 years 5 months ago #196027
Bushes wear first, then pins.
It depends on how much wear there is if pins need replacing also.
The following user(s) said Thank You: Gavin207
Time to create page: 0.471 seconds
