1998 VVC Compression Test
I’m trying to do a engine compression test on my 1998 VVC. To prevent pumping fuel during the test I want to remove the fuel pump relay. The relay is situated in the most awkward location to the right of the footwell fuse box behind the dash structure and I’m having difficulty removing this. It appears to be located by a base clip. Has anyone any advice as to how this can be removed or is the an alternative to isolating the pump? I've tried removing fuse 14 but with this out it will not crank.
Last Edit:3 years 5 months ago
by peterd
Last edit: 3 years 5 months ago by peterd.
- sworkscooper
Have you tried tapping the inertia switch , as in the event of a collision this shuts off the power to the pump . You may have to remove it from the engine bay to do this as it's easier to hold it and tap it .
John
John
by sworkscooper
The following user(s) said Thank You: peterd
Would disconnecting the inertia switch achieve the same?
by peterd
Done compression test with following results
Cylinder 1 - 165
Cylinder 2 - 165
Cylinder 3 - 152
Cylinder 4 - 158
Cylinder 1 - 165
Cylinder 2 - 165
Cylinder 3 - 152
Cylinder 4 - 158
by peterd
All within 10% so no real problem indicated there.
Time to create page: 0.492 seconds
