Switched / Unswitched Live Feed
Switched / Unswitched Live Feed was created by Fisher
Posted 3 years 3 months ago #196551
Hi All. We all have added electrical parts to our cars, Driving lights, Spotlights, Garmin etc. I have, and it appears also the previous owner. However, looking under the centre dash the maze of unknown wires, spliced, and unknow origin, is a little concerting. So decided to remove and start again. As we all need a switched or unswitched (I prefer switched) supply this is where I will start. I was thinking about fitting a common live/not live. junction box/connector block  with perhaps 6 connectors you could tap from. So, would you:
1 Use a terminal block (household wiring type) or fancy junction box?
2. Where would you take the live feed from? Where would you take the non-live feed from? And what AMP rated cable would you use?
3. Would you fuse to the teminal block, again what AMP fuse.
4. Where would you suggest this block/tetrminal is located?
Naturally each connection from the block/terminal would be individually fused.
Finally, when connecting any accessory to the block/terminal what AMP wiring would you use i.e. 8, 10 15 AMP auto cabeling?
As you can see from my questions I am not an electrical expert, but wish to standardize my wiring for safety and any future owner.
Found this online. Look OK for my application.
Rob
Last Edit:3 years 3 months ago by Fisher
Last edit: 3 years 3 months ago by Raccoon. Reason: pic added
Replied by talkingcars on topic Switched / Unswitched Live Feed
Posted 3 years 3 months ago #196562
Finally, when connecting any accessory to the block/terminal what AMP wiring would you use i.e. 8, 10 15 AMP auto cabeling.
1) Don't use choc blocks for automotive situations, use crimped or soldered connections.
2) Depends on the application
3) Depends on the application
4) Depends on the application
Remember that getting automotive wiring wrong could lead to a fire.
Replied by Fisher on topic Switched / Unswitched Live Feed
Posted 3 years 3 months ago #196573
Thanks Julian. I am doing exactly as you did, stripping out the wiring and starting again. I have bought a six-way blade fuse box, similar to the link you suppied.
Excellent idea to mount it on the inner lid of the drivers panel. That is the way I will go.
Thanks again exactly what I was looking for.
Rob
by Fisher
Posted 3 years 3 months ago #196574
I too have a small 6 blade box in the internal fuse box area for the feeds for the heated seats and the cruise control.
I used a EPAS fuse holder mounted on the inner wing by the normal EPAS fuse but it's for the electric vacuum pump for the brake servo.
Posted 3 years 3 months ago #196577
Hi James
Besides the drivers panel as Julian suggested, I am also looking at the inner wing by the main fuses.
As you did, I may also be looking to install two fuse holders. Cannot make a firm decision untill I receive the fuse holders, as see sizes etc, and sort out the current spaghetti mess of wires
Thanks for your input
by Fisher
Posted 3 years 3 months ago #196582
You are welcome.
I also stuck a couple of fused relays next to the under bonnet fuse box for the heated windscreen.
Time to create page: 1.363 seconds
