engine low on power
engine low on power was created by Fordmill
Posted 3 years 3 months ago #196679
Hi Folks,
Hope everyone safe and well. Ifeel that my tf 135 is lower on power, has any one got any thoughts on how I can improve the power as its sluggish?
Thanks
Replied by talkingcars on topic engine low on power
Posted 3 years 3 months ago #196682
The first thing to do is to establish that the car is running on full power.
Replied by Fordmill on topic engine low on power
Posted 3 years 3 months ago #196696
I have found a vacuum pipe on the n/s/r of the car but is not attached to anything, anyone got any ideas where it goes?
Regards
Replied by BruceTF135 on topic engine low on power
Posted 3 years 3 months ago #196778
Are you sure that it is on the NEAR side rear of the car? The TF (certainly around 2004) had a strange vacuum controlled valve on the right-hand exhaust tailpipe. This is usually disconnected, plugged, and tied up out of the way when replacing the backbox. I believe that the valve was something to do with reducing noise at low revs (around town) for the USA market.
Posted 3 years 3 months ago #196783
The valve closed the off side exhaust.
Replied by bryan young on topic engine low on power
Posted 2 years 8 months ago #198589
Almost correct!!!! firstly the MGF &TF NEVER WENT TO America!!!! the vacuum controlled exhaust valve was to pass the ''drive by noise test'' by closing the off side exhaust pipe for drive by speeds. it was controlled by vacuum from the ECU and was 'opened' as speed increased. the valve normally seized in the open position. MG Rover dropped this device after a couple of years >
Time to create page: 0.497 seconds
