quick tip for binnacle/instrument cluster
quick tip for binnacle/instrument cluster was created by deepfat
Posted 3 years 2 months ago #197055
Not sure if this will work as it's the first time i've attempted to attach a picture.
In the picture you can see my binnacle has cracked exactly where the white nylon mounting inserts into the binnacle and this introduces a spreading load into the binnacle as they open to accept the screw.
When I replaced the binnacle I took out these nylon mounts and replaced them with a speedclip which is also in the photo. I glued these to the back of the binnacle with contact adhesive, this allows the clip to self centre if you have not got it exactly lined up and means they stay in place when you remove the screws in future.
This changes what was a spreading load into a compression load that the binnacle can handle much easier, if your doing any work in this area it will only take a few minutes and may save an expensive binnacle.
Last Edit:3 years 2 months ago
by deepfat
Last edit: 3 years 2 months ago by Raccoon.
The following user(s) said Thank You: sworkscooper, mnripley
- neilpinleeds
Replied by neilpinleeds on topic quick tip for binnacle/instrument cluster
Posted 3 years 2 months ago #197056
Your picture isn't showing.
Update: Photo inserted. Bertl
by neilpinleeds
Time to create page: 0.578 seconds
