can you kid the SRS
can you kid the SRS was created by deepfat
Posted 3 years 1 month ago #197091
This post is prompted by devilheart's problem with his SRS light.
Does anyone know what signal the chip is expecting back from the relative SRS component (seat belt/air bag), can the signal be mimicked?
I'm just thinking instead of changing bits in turn until the light goes out we disconnect the part and mimic the signal, if the light goes out that's the dodgy one. This is probably a very simplistic view (that's me simple) and I presume interrogation via the OBD port would tell you which one is duff (yes/no), but we don't all have access to these systems.
by deepfat
Replied by talkingcars on topic can you kid the SRS
Posted 3 years 1 month ago #197093
The www.pscan.uk will be that device you plug into the OBD port.
You can plug a resistor in to the terminals of the SRS component to give the SRS ECU a false reading but I have no idea of details.
Replied by julianfoulger on topic can you kid the SRS
Posted 3 years 1 month ago #197108
I did do a search for 'devilhearts' problem (search term 'SRS') and found nothing so I have no idea what the problem is.
As a general rule, other than replacing individual components one at a time (rotary coupler, airbag, seatbelt restraint units, SRS ECU)..., I would never attach a multimeter to the SRS system to test continuity et al only because I would be frightened of setting off the unit with a bang!
I assume that within Rover's Testbook, was an SRS diagnostic component to detect exactly where the problem is in the SRS circuit.
The resister idea of talkingcars is a good one but likewise no idea what resister et al.
EDIT: Found the post of devilshearts. He is doing exactly what I would be doing in his shoes. ie The above.
Last Edit:3 years 1 month ago by julianfoulger
Last edit: 3 years 1 month ago by julianfoulger.
Replied by SundanceUK on topic can you kid the SRS
Posted 3 years 1 month ago #197110
I think the resistor is quite a low value - top of my head its either 6 or 3 ohms
Sundance
Posted 3 years 1 month ago #197116
.....I assume that within Rover's Testbook, was an SRS diagnostic component to detect exactly where the problem is in the SRS circuit......
The pscan interrogates the SRS ECU, I guess Testbook does the same.
Time to create page: 0.689 seconds
