scraping from left when turning right.
scraping from left when turning right. was created by Shedifice
Posted 3 years 1 month ago #197327
Hi all,
Just had a development in my 'new' tf. at slower speeds when I turn right I am getting a repetative scraping noise timed with the wheel rotation. I think its rear but could be front.
It has new disks and pads (by last owner). I had both wheels off but cannot see anything like a shield or teh like interfering with the disk.
I would expect a wheel bearing to be more constant and a CV to be more clonky.
Any ideas? seem to be louder freewheeling and less under loadthat poss leads to more driveshaft related issue.
Leigh.
Replied by bryan young on topic scraping from left when turning right.
Posted 3 years 1 month ago #197329
Could be the rear calliper has seized and the pads are rubbing on the disc, this can happen if the car is left for long periods with the handbrake on. the rear callipers are notorious for seizing on the 'TF' & 'F' jack the car up and see how easily the rear wheel turns with the handbrake off??
Replied by Shedifice on topic scraping from left when turning right.
Posted 3 years 1 month ago #197330
The rear was noticeably stiffer than the front. What is the best unseizing strategy? Not tinkered with one of these before. I'll have a flick in the how to as well to see if anythiing there.
Posted 3 years 1 month ago #197331
Just read through a few how to's on the AP calipers. Am i right in thinking these calipers you can press the pistons in and dont need a tool to wind them in?
L
Posted 3 years 1 month ago #197332
Yes, there is something in the ''how to'' guides about the handbrake on the rear callipers , another thing is the clevis pins that seize in the yokes i freed mine with Plusgas and working back and forth only to find out that Mike Satur does these complete with 'R' clip in Stainless Steel for £5 so i bought some but still have to fit them -
Posted 3 years 1 month ago #197333
YES, the pistons on the AP's just push back but the rear callipers ideally need a wind back too to wind in the pistons,. or you can use pointed nose pliers or the 'C' spanner from a disc grinder
Posted 3 years 1 month ago #197334
Going ''off line'' now need to eat !!!!!!
Time to create page: 0.482 seconds
