mgtf rear window opaque
I've just sent mine away to have a new panel fitted, ebay item number 254234496505. You will need rivets and a foam strip to re-fit the window.
- BruceTF135
If it is damaged, replacement is probably the only solution. Try eBay or look around for someone that does car hoods, boat covers, caravan awnings or similar.
- bryan young
Also the oxidisation makes the screen brittle and liable to split.
I did mine with graygate polish, only around £7 from eBay and you don't need much.
Used by BT, NASA and Talkingcars, must be good.
The screen goes opaque due to oxidisation so polishing to remove the oxidisation will take it back to clear.
Used by BT, NASA and Talkingcars , must be good.
Can't get a better recommendation than that!:woo2:
