Winter Lay Up
- neilpinleeds
What is the best sequence for disconnecting the battery (an isolator is fitted)? Does disconnection trigger the (Pecktron) alarm? Once the power is off can the doors be locked/unlocked with the key? Can the boot still be opened with the key?
I'd say daft questions, but my mate is currently completely locked out of his MX5 after just disconnecting the battery and closing the bonnet.
I plan to start the car up monthly.
- BruceTF135
- Slidehammer
- Novice MGer
- mucklestone
- Apprentice MGer
However you would have to lock the car manually and the alarm would not work.
I'd be more worried about brakes sticking on. I leave them off but that's in a locked, flat garage with tyres in tyre savers. Would be irresponsible outside - there are stories of cars rolling away when kids nick the brick from under the wheels.
....Would be irresponsible outside - there are stories of cars rolling away when kids nick the brick from under the wheels.
Leave it in gear.
Once the battery is disconnected use the key to lock the car.
Personally if the car is going to be laid up for a while I connect a trickle charger and lock with the key.
- mucklestone
- Apprentice MGer
Leave it in gear.
I didn't think of that lol, talk about missing the obvious!
Though with Covid mine sat in its garage for months so I wedged the clutch down
- bryan young
- neilpinleeds
However a three times round the block blast identified a not insignificant miss fire that got higher up the revs as the car warmed up but didn't fully disappear.
Is this a known symptom for TFs left unused outdoors? damp/corrosion in the throttle body? Or just our new friend E10 sat in the tank absorbing water?
