Oil filling
Oil filling was created by Andy661
Posted 2 years 11 months ago #197775
Afternoon everyone...
Finally have my spares on the way thanks to the lovely chaps at MGRDS...
But I have a question... :-?
The TF has a remote oil filler, but when you remove the engine cover, the original is visible... I've read that the remote can take a long time to fill from, since I'll have everything accessible for changing the HG, is there anything wrong with using the main filler to fill the oil?
Thanks in advance!
Andy
by Andy661
Replied by gloscs on topic Oil filling
Posted 2 years 11 months ago #197776
Hi Andy,
The engine original filler is the easiest and quickest way to fill the engine with oil, but you have to remove the engine cover. The remote filler is really for topping up but there is no reason for not using it for an oil change just takes longer for the oil to filter through.
by gloscs
The following user(s) said Thank You: Andy661
Replied by SteveFMk1 on topic Oil filling
Posted 2 years 11 months ago #197778
There is an easier way, if you have small hands, remove the grill above the expansion tank, then you can slide your hand in and unscrew the filler cap on the cam cover. Next 1 metre length of garden hose pipe, push a small plastic funnel in the end, use a a small length of wire to hook through the eyelet on the funnel and then hook the other end through the bracing under the boot lid.
If you top it up the night before you use it, it will give all the oil time to drain out of the pipe and cuts the mess down when you put it back in the carrier bag.
That's how i do it.
Replied by Andy661 on topic Oil filling
Posted 2 years 11 months ago #197782
thanks guys... that's what I suspected but just wanted to be sure...
Measure twice, cut once! :slapme:
by Andy661
Time to create page: 0.605 seconds
