Camshaft sensor
Camshaft sensor was created by kevinMG
Posted 2 years 11 months ago #197863
In an attempt to cure my rev limiter, or high speed misfire problem I decided to change the cam sensor. Unfortunately here in South Africa I can only get the long pin sensor which other than the pin length is absolutely identical. Does anyone know if the internals are the same and can the longer pin be machined down to match the original, and how much the pin should project from the body of the sensor?
Last Edit:2 years 11 months ago by kevinMG
Last edit: 2 years 11 months ago by Raccoon. Reason: pic added
Replied by G0RSQ on topic Camshaft sensor
Posted 2 years 11 months ago #197884
I am sure the long pin sensor is the CRANKSHAFT position sensor.
The CAMSHAFT position sensor does not have the pin.
by G0RSQ
Time to create page: 0.516 seconds
