Front Brake Calipers
- Chris P Dash
- Apprentice MGer
As I'd got the rear pipes disconnected I decided to take the opportunity to replace the rear flexi pipes with a set of braided hoses - I've also has some issues with the rear brakes binding and looking at the state of the rear calipers decided 'in for a penny' and have fitted a new rear set.
This is my first dabble into brakes but this part seemed to go remarkably well (which is unusual for me!!)
However!! as the braided hoses came as a full set I then made the decision to replace the fronts... and this is where things have taken a turn for the worst!
Firstly there was no way on earth the brake pipes wanted to part company with the flexi hoses - after completely destroying the nuts I made the decision to cut the pipes and replace - I don't have the kit to make new sections so will need to visit my local garage again in the new year (the rear section they made for me was spot on!)
Now.. whilst the front pipes are disconnected I thought it would be a good idea to remove the calipers and give everything a good clean (my car is the 160 so has the AP twin pot calipers)... and this is where my troubles begin! ..
I was unable to remove the lower pins on both calipers (the top one's came out reasonably easily).. in my various efforts to get them out (which I've finally done) I've managed to break the a caliper wear slide..
So.. from what I've found online it would seem that removing the retaining screw for the sliders is not that easy - so before I try and then round off the head what would you recommend are my best options? ..... Thanks.
- bryan young
You say that your callipers are 2 pots ( one piston each side) if they are, yours is the first TF that i have come across with 2 pots factory fitted, they were another cost saving and were apparently fitted to the MY2005 (Feb 2005) cars , then MGR went bust two months later !!! i have not found a car with them fitted .
Good luck with your brake pipes.
- bryan young
- Chris P Dash
- Apprentice MGer
Two wear plates are broken and the rest don't look too good - I think now they're off a refurb is on the cards.. kerrching!!
- SundanceUK
I usually strip, clean and re-grease with anti seize every year which stops things from corroding up.
If you have trouble finding new bolts for the caliper halves, I have a few sets spare at minimal cost.
Sundance
But where is the creativity in that?cheaper/easier than inventing new swear words.
I myself, over many years working on cars, boats and machinery, have amassed quite a back catalog in , obscenities, profanities, blasphemies, damnations, taunts, oaths, curses, insults, threats and abuses.
All used in to varying effect on recalcitrant components, in fact about the only things I haven't tried in motivating stubborn parts is expose by bumhole at 'em or waggle my willie in their direction.............Hmmmmmmn! There's a thought, I wonder if that"ll work! :bust:
- SundanceUK
Sundance
- SundanceUK
Sundance
