Broken T piece
- Simon Morriss
- Apprentice MGer
Hi All
My MG TF has suffered a broken T piece on the cooling section of the engine on the end of the pipe that returns the coolant to the expansion bottle.
Speaking to a local garage over the phone we decided that pipe section 64 on the MG expanded drawing was the part I needed as the T-Piece was not available. On receiving the hose it's nothing like mine, in the picture you can see where the hose has broken on my MG.
I have now studied the schematic drawing closely and I can't find anything similar to the part I need so I'm wondering if there has been a change of design and now this part is not available. What I can confirm is that a metal pipe feeds into this section which make me think the design has now changed.
Any help will be amazing.
Thanks
Simon
Thanks
Simon
Not sure if its of any use, but there was a guy doing a lot of work on a TF and posting it on youtube (MGLEE)... he recommended the Rimmer Bro's catalogue and says the expanded drawings were pretty good, I've not seen one myself so cant confirm...
Failing that, I'd give DMGRS a call! the guy I spoke to there was very helpful in sorting out the parts I needed and I imagine they'd be able to tell you just by looking at the photo. :broon:
by Andy661
The following user(s) said Thank You: Simon Morriss
- julianfoulger
T piece is not sold as a seperate piece but part of a much bigger hose piece. You need either PEH100790 (non-VVC) or PEH100940 (VVC). It has been like this for some years now.
I think that the Cooling System Bleed valve- PEI100010 - is not available as a seperate item now either and may form part the items above.
Last Edit:2 years 10 months ago
by julianfoulger
Last edit: 2 years 10 months ago by julianfoulger.
The following user(s) said Thank You: Andy661, Simon Morriss
Time to create page: 0.661 seconds
