Another little project...
Our cars not as bad as cars with full window surrounds, but could still severely hurt someone if accidently activated and hood/hard top was up/on.
The base software is running on an Arduino. I just need to define the locking characteristics. I would like the ECU to give me two minutes from ignition off before cutting off enable to the switches and thirty seconds after locking before a second locking instruction will not raise the glass. After that, the ECU will shut down until the ignition is enabled again.
My Alfa 159 has an interesting alternative solution - hold down the unlock button on the remote fob and all the windows open, with my previous 159 holding the lock button would close them as well but not this one.
You may find that there is a sequence to make that happen. Worth enquiring of the Alfisti.
Apparently remote fob total closure was deleted for safety reasons. It still works on the later car through the key in the door lock.
- SundanceUK
Sundance
