Felix won't start
- adamelphick
Yesterday I tried in vain to get him to fire up.
Put fresh fuel in, charged battery, used extra battery, had jump leads on from ZS, you name it!
It's been around 5 months since he last started, and before that he would fire up immediately.
What should I look for first?
Ta, it's been a while I was in here!
- adamelphick
I want to get him started so that after 3 years nearly off the road I can get him sorted again. I need to finish my custom dash and get it covered.. then I can reinstall the interior....
Back in the old days of carbs I was told spray easy start in the filter, if it started (briefly) or seemed to be starting you had a fuel/carb prob, if it made no difference check the sparks/timing etc. As above though I would seek confirmation that no damage will be done before trying it.
- adamelphick
Have you tried to start it again yet:?
Not yet... It's been pissing down :dry:
- adamelphick
Supposedly it isn't going to rain tomorrow - so I'll get the million 10mm nuts out and cover off and see what's up LOL
- adamelphick
Anyway I sprayed a touch of carb cleaner in the throttle body and he fired up, then immediately died... Hmmm fuel pump - surely not?!
Pulled off the connector and popped my multi-meter across the power wires, turned on the ignition and got 12v.. listened for the reassuring buzz when it first primes and nothing. Weirdly there was a bit of fuel in the upper fuel line when I disconnected the (orange?) push fit connector. I popped a bottle over the pipe and turned on the ignition again and nothing pumped out. I am guessing it should? So I think his fuel pump has given up the ghost?
I had one in the shed, from Fleur (my Amaranth F that died many years ago), grabbed it and BUGGER - it's got a different plug! I suppose the Lucas and Pektron cars have different ones?
Is there a way to test the pump other than pulling off that pipe and seeing fuel? I pushed the fuel cut-off switch just in case it was that but I am assuming not as there was 12v at the pump wires?
Help appreciated before I go and look for a pump! (unless I can splice the old style plug on? Pretty sure I have a loom that will have the correct plug in the shed.
Ta
- adamelphick
