Felix won't start
Replied by Cobber on topic Felix won't start
Posted 2 years 9 months ago #198489
Before you get too involved in pulling shit apart and fiddle-arseing about with things that may well be best not disturbed, hows the fuel filter?
Do you have flow at the line before the filter?
It's probably about due for replacement anyway, so why not whack a new one in and then see if the car shows a bit more enthusiasm to proceed in the desired fashion. It would save the fire risk of running the pump with open fuel lines and splashing fuel from arsehole to breakfast!
The proper way of doing it is to use a fuel injection pressure test gauge, with the suitable adapter fittings.
Last Edit:2 years 9 months ago by Cobber
Last edit: 2 years 9 months ago by Cobber.
Replied by adamelphick on topic Felix won't start
Posted 2 years 9 months ago #198491
The fuel filter was replaced just before he was laid up - and he started fine just before Christmas - but good call - I'll check if any flow before the filter just in case!
But I do remember hearing the normal 'bzzzz' of the fuel pump priming on every key start before.. which it isn't doing now. It's silent as a mouse.
Replied by julianfoulger on topic Felix won't start
Posted 2 years 9 months ago #198495
Fuel pump often fails of left unused. Check these barn find videos and often the fuel pump is dead.
The following user(s) said Thank You: adamelphick
Posted 2 years 9 months ago #198515
Blimey will it ever stop raining and blowing a gale so I can look more into this?! :rant:
Replied by sworkscooper on topic Felix won't start
Posted 2 years 8 months ago #198554
Have you managed to sort it Adam ?
Posted 2 years 8 months ago #198555
Not yet - weather has been poop - then fence blew down in garden (took time up) - then bloody kitchen got a flood (deep joy) and now ZS needs a new O2 sensor and MOT LOL
I am pretty sure it must be the pump though as it's getting 12v but is silent as a mouse.. normally makes that little 'whirr' when the ignition is switched on.
Posted 2 years 8 months ago #198566
Am I right in thinking that Felix is the car with the ' Frankendash ' ? I haven't seen any posts of the finished item !
Last Edit:2 years 8 months ago by sworkscooper
Last edit: 2 years 8 months ago by sworkscooper.
Time to create page: 0.513 seconds
