Gearbox oil change
Gearbox oil change was created by Bobb
Posted 2 years 8 months ago #198537
Hi, I’m a very hopeless and reluctant mechanic, is it an easy job to change gearbox oil and do I need any special tools?
by Bobb
Replied by BruceTF135 on topic Gearbox oil change
Posted 2 years 8 months ago #198538
You will need to be able to work under the car. I think the drain plug needed a square or hex drain plug key/allen key. You need something to catch a few litres of oil. To refill the gearbox you will need a length of suitable tubing as, unless you have a large syringe or similar, you need to fill it from the top of the car. Make sure that you can undo the filler/level plug before taking out the drain plug. On my car, there was no drain plug washer which didn't seem right, so I used a compressible aluminium washer (spare sump plug washer, if I recall).
It's easy.
Replied by Bobb on topic Gearbox oil change
Posted 2 years 8 months ago #198540
Thank you, you’ve given me the confidence to give it a go.
by Bobb
Replied by trevtherev on topic Gearbox oil change
Posted 2 years 8 months ago #198556
Yes, I found this to be a fiddly job, but enlist some patience and all will be fine. I used MT94 oil which I got online from Smith and Allan
Time to create page: 0.499 seconds
