Catalytic converter flange
Catalytic converter flange was created by Gavin207
Posted 2 years 8 months ago #198635
So my exhaust unbelievably has lasted for over 2 years despite looking like this it doesn't leak and unfortunately it won't go on forever and the catalytic converter flange is very corroded does anyone have a solution for rectifying this - is it possible to weld a new flange onto the catalytic converter pipe or is there another solution?
Replied by Steve on topic Re:Catalytic converter flange
Posted 2 years 8 months ago #198636
My solution was to buy an aftermarket klarius Cat from mgfntfbitz for£120 and sell my old leaky cat to a scrap merchant for £760, problem solved, also means I cashed in before the scrotes stole it.
by Steve
Replied by Gavin207 on topic Re:Catalytic converter flange
Posted 2 years 8 months ago #198637
What am I missing here? Why will they pay 5x the cost for a new CAT for a 20 year old CAT - unless they have significantly less active material in them and a much shorter life, or is there something else?
Replied by Steve on topic Re:Re:Catalytic converter flange
Posted 2 years 8 months ago #198638
Materials used in new cats are cheaper (nor precious metal) and therefore cheaper, if you buy one a I did look for a guarantee, mine came with 2 years so I can can change it every 2 years for almost 8 years without loss but I'm sure that won't be the case, by the way the one I bought are also badged as MG Rover oem by the like of Rimmers at a premium, and by the way you can buy replacement flanges to weld on if you are so inclined but if you existing is salvageable and able to be welded it could eventually collapse inside and become worthless.
by Steve
The following user(s) said Thank You: Gavin207
Replied by neilpinleeds on topic Re:Re:Catalytic converter flange
Posted 2 years 8 months ago #198639
Isn't it only the earlier MGF cats that are so valuable? I don't think the TF cat is worth much?
Replied by Bob on topic Catalytic converter flange
Posted 2 years 8 months ago #198641
I used one of these but you'll need a welder. https://www.mikesatur.co.uk/-MGF-MGTF-Exhaust-or-Cat-Flange-Repair-Kit
by Bob
Replied by Gavin207 on topic Catalytic converter flange
Posted 2 years 8 months ago #198642
I assume I'd need stainless welding wire - not something I've tried yet with my MIG. Bearing in mind the existing CAT is 17 years and 113 miles old, how long can you expect an original CAT to last?
Replied by Cobber on topic Catalytic converter flange
Posted 2 years 8 months ago #198643
There is no great mystery to mig welding stainless steel and yes stainless mig wire is required if you're welding stainless to stainless, but wont matter much if you're welding stainless to mild steel, by the look of the state of it in the pix, you're going to be trying to weld stainless to shit.......bin it and start again!
Replied by Wincey on topic Catalytic converter flange
Posted 2 years 8 months ago #198675
fixed mine by cutting cat and tailpipe flange with angle grinder leaving two open pipes. Guy on eBay makes pipe connectors to order. Therefore cutting out flange connection. Worked fine, passed MOT..
If interested let me know, I'll give you more details.
Ian
by Wincey
Posted 2 years 2 weeks ago #200384
So I decided to take the exhaust and CAT off the car as I need to change the lambda sensor and couldn't shift it on the car. The CAT/exhaust flange connection didn't survive as you'll see below.
Although the exhaust still isn't leaking I'm considering changing the CAT and exhaust as it can't last much longer, and at 118,000 Miles I wonder how much longer the CAT can last. Also
So I'm considering a CAT and mild steel standard silencer from mgfntfbitz.
Question - how long do the mild steel silencers last, as at 1/3 of the price of a s/s unit
Also what can I expect to get scrap for an original TF CAT, and where's best to sell it?
Posted 2 years 2 weeks ago #200385
Gavin207 wrote: So I decided to take the exhaust and CAT off the car as I need to change the lambda sensor and couldn't shift it on the car. The CAT/exhaust flange connection didn't survive as you'll see below.
Mild steel back boxes can last a long time (years) provided that condensation drys up so on longer drives etc, although a SS exhaust will sound better if thats what you are after (depending on which one some LOUD others not so much) as far as cat value I sold my MK2 F cat for £760.00 they had been as much as £900 but prices fluctuate and it all depends on the code on the back, mine was KAT 010 but I expect £200 as a minimum currently, not sure where you are but google for local buyers, I sold mine at Warrs in Birmingham.
by Steve
Time to create page: 0.529 seconds
