Gearbox oil, refill
Gearbox oil, refill was created by Bobb
Posted 2 years 8 months ago #198644
Hi Everyone,
Where is best to refill the gearbox?
Is there a refill plug?
Of do I remove the reversing sensor?
Do I gain access from above the engine bay?
Sorry for all the questions, but I’m a total novice.
Thanks for your patience.
Bob
by Bobb
Replied by Pharg55 on topic Gearbox oil, refill
Posted 2 years 8 months ago #198645
Hi Bobb,
I've just done this recently, with the car raised. Found it easy to do, using an oil syringe. There is a drain plug, as well as a fill/level plug, takes approx 2ltrs to refill.
Hope this helps.
by Pharg55
The following user(s) said Thank You: Prof Riley
Replied by Gavin207 on topic Gearbox oil, refill
Posted 2 years 8 months ago #198646
One of these £10 in toolstation
Last Edit:2 years 8 months ago by Gavin207
Last edit: 2 years 8 months ago by Gavin207.
The following user(s) said Thank You: Bobb
Posted 2 years 8 months ago #198647
17mm filler, consider replacing the aluminium washer. The drain plug can be removed with a 3/8 wrench
The following user(s) said Thank You: mnripley, TwistNShout
Replied by Bobb on topic Gearbox oil, refill
Posted 2 years 8 months ago #198648
Hi Gavin,
Thank you so much, this is just what I needed... pictures!
Bob
by Bobb
Replied by Prof Riley on topic Gearbox oil, refill
Posted 2 years 8 months ago #198651
Agreed, Thank you!
Replied by G0RSQ on topic Gearbox oil, refill
Posted 2 years 8 months ago #198653
Dont forget, undo the filler plug before the drain plug!!!
Nothing worse than draining the oil, then finding the filler plug is corroded solid, and you cant get it out!!!
by G0RSQ
Posted 2 years 8 months ago #198654
Great tip.
I couldn’t release to top-up plug, so I’m glad I took your advice!
by Bobb
Time to create page: 0.522 seconds
