Which impact wrench?
I need advice and suggestions on which impact wrench to buy.
I’m, like most people on this forum, a reluctant mechanic, so I don’t need a garage standard impact wrench as it’s only going to get occasional use.
Bob
My advice is to look for one that will produce more than 400Nm, most do nowadays. Unless you plan to use it all the time I wouldn't spend a lot. Machine Mart have a good comparison facility on their website - https://www.machinemart.co.uk/categories/?search=impac&suggest=true&Category=Power+Tools%7cImpact+Wrencheshttps://www.machinemart.co.uk/categories/?search=impac&suggest=true&Category=Power+Tools%7cImpact+Wrenches
However it is massive and heavy, but it will spin off a wheel hub nut with no problem.
Why do you think you need one? I do a lot of mechanicing and have never really needed one. £20 buys a good breaker bar.
I find best use for impact wrench when it is difficult to get a good "torque reaction" from a breaker bar.
For example the crankshaft bolt, where the crank wants to turn, a bolt on the suspension that wants to lift the suspension as you turn, or a tight bolt on a small component removed from the engine.
Trying to stop something moving, while using a breaker bar can be difficult, but an impact wrench will "hammer" it off.
Dont use one often, but when it is needed it is a godsend...
- trevtherev
- Journeyman MGer
That's the way to do it.
the consensus appears to be, don’t bother, invest in a good socket set, plenty of WD40 and perhaps go down the gym occasionally!
Working on cars, I find them the most use on rotating components such as undoing flywheel bolts, crankshaft pully bolts etc. and anywhere there is no swinging room for a long breaker bar.
On the down side you need head room above the bolt head to use them.
I don't bother with mains powered units, none of the convenience of battery power and without the grunt of pneumatic, I see no advantage in them.
I only use Bosch Professional or Hilti battery rattle guns, although I have an Aldi 1/2" drive battery rattle gun which I always carry in the ute for wheel changing (don't care if it gets stolen) it's a little bulky but is much better than I thought it would be, it provides a very good bang for the buck.
Although you can get square drive adapters for impact screw driver guns, the damned things are next to useless for automotive work, better off leaving those things to wood butchers!
